b18b in eg
turbo'd ls eg
ok i got the motor in and all the mounts and wiring.. the only problem is the stock throttle cable wont work, and either does a gsr. which throttle calbe do i need?
i always use the factory one just make a bracket and then mount it up leave a little slack in the cable works great check for full throtlle and you are done or buy an ls integra one
i used the integra one (a type r one, but doesn't have to be) and it fit perfectly fine on my car, it was a b16a into an eg hatch
I am using a throttle cable from the 1990-1993 Integra in my 92 Civic with a B20B.
