b18b into 93 civic dx
david
want to know what i need to put a b18b into a 93 civic dx? i have the motor,ecu,wires,tranny,ls shift linkage,and the motor basics
you should be all set then
will axels from the dx work with the b18b,will the shift linkage from the b18b fit up to my shifter and all the mounts will bolt right up then?
no you need the B series axles from the LS
and yes the linkage will bolt right up to your shifter
hell yeah thinks man its good to have people like you in this place
