B18b into 99 CX Hatch
Status
Not open for further replies.
lukedogk12
ek hatch
I finally decided...I'm doing the b18b swap in my 99 civic cx hatchback. I've heard that the motor is OBD2a from some and OBD2b from others. I think my car is OBD2b (please clarify if I'm wrong). What would a b18b from a 99-00 integra's OBD be? Let me know what would be the best b18b to go with, I pretty much want to just drop it in no wiring issues (except for wire lengthening). Thanks.
Since you will be re-using the civic's harness you should only have to worry about the ECU, the wiring will plug in just fine to the engine no matter if it's obd2a or b
Ask in the ecuelectronics forum as to what obd your car is, I can't remember if they changed it in 99 or 01
The engine is plug and play, I am not 100% on the computer
you'll need integra axles.. but 99-01 is obd2b and i'm pretty sure the plugs on the ecu are different..
Status
