B18b Ls Some Weird Sh!@t
Discussion in 'HYBRID -> EG-EK / DC' started by flippedcivic95, Jan 6, 2003.
  1. flippedcivic95
    flippedcivic95 Junior Member
    HOUSTON TX
    ok i did an ls swap the other day in my vtec-sohc eg civic and it wont start ok here is what it is doin: ok i am getting fire to all the cylinders ok but i am only getting gas on the 1st and 3rd injector and the 1st injector is spitting constant fuel and flooding the first cylinder as soon as i turn the key but the 3rd is working fine and i have changed the injectors and the rail is filling up with fuel but its all screwed up and my car wont run please help it is throwing a code 16 fuel injection so i dunno can someone help oh yea and the second and 4th cylinder is getting no fuel thru the injectors help!!!!!!!!!!! :eek:
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    what year is the engine and what ecu are you using?
  3. flippedcivic95
    HOUSTON TX
    it is a 94 motor my car is 95 both obd1 and i am using a p28 ex/si ecu
    i was told that the ecu should still start the car
  4. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    i'd run the proper ecu first to eliminate that variable.
  5. flippedcivic95
    HOUSTON TX
    u think the vtec not being would effect the fuel it is throwing a vtec code and fi code
  6. prawjEKt Cx
    upstate NY
    i'm just saying it can't hurt, even to take a doner ecu from a buddy or somthing.
  7. flippedcivic95
    HOUSTON TX
  8. nuc79
    nuc79 Senior Member
    SE Georgia (near Jacksonville, FL)
    Check your injector wiring. There is no reason why the P28 shouldn't run that engine(poorly, maybe, but it should run).
    If I remember right, the injector harness feeds up from the passenger side of the intake on the D16Z6, and from the drivers' side on the B-series. It's possible that the injectors could be plugged in ass backwards. We ran into this problem with a B16A swap. Had spark, had fuel pressure, and the engine would run for a couple seconds if about a spoonfull of gas was porred into each cylinder through the plug hole. That's when we knew it was injectors or injector wiring.
    I've got a 94-98 teg service manual with wiring diagrams if you want to know for sure what color wires go to what injectors.
    HTH
