i got an ls from a 93 integra..im swapping it into my hatch, do i have to buy swap mounts or can i use the integra mounts or can i use 1999 or 2000 civic si mounts? All help is thankful.
I believe that you will need 94-01 integra mounts for this swap. Also, the 93 teg trans won't work in a 93 civic because it is a cable trans, where 92 and newer civics use a hydraulic tranny.
i'm in the same boat right now i have a 92 eg with a ls swap from 97 integra.. its been hell. i'm new to all this and learning as i go. i am stuck with the rear mount trrying to figure out what to do....
whats wrong with the rear mount? Make sure that the bracket is bolted to the engine befrore dropping it in. Also, make sure the bracket is alligned in the mount first before trying to bolt down the other mounts.
