B18b w/ Auto Gsr Tranny
braden71385
I just purchased a B18b motor and a automatic gsr transmission. I have been looking for the ECU to use for this setup, which is a p75 i think? Do they make a automatic version & a m/t version p75, or is there just one p75 ECU that works for both auto or m/t transmissions? My next question is... what else will I need to complete this swap? I would also like to buy my ECU already chipped w/ all the performance settings done to it, anyone know of a place that does that sort of work?
:unsure:
Are there any sites that test out parts to see which company has the best hp & torque gains on each part?
Thanks
auto GSR tranny? JDM? cuz theres no auto GSR tranny in the states.
the ls came with auto's, and the p75 in auto form will be stupid easy to find at like any junkyard. you can't use them on both- auto = auto, manual = manual, unless you chip one to work as the other.
if your motor is stock, theres no need to chip your ecu. you're just going to lower your gas mileage and loose horsepower.
what else do you need? consult our swap section for a general overview.
