keehnel1414
I looked in you swap section because i want to swap a b18b into my civic hatchback what does this me " B18B: Completely bolt-in swap, SIR II, Hasport shift linkage. Del Sol VTEC for the del sol"
I get the completly bolt- in swap, but what does the stuff after that mean (SIR II, Hasport shift linkage. Del Sol VTEC for the del sol)
Another question i had is will a turbo kit work when the engine is in the hatchback or will i need to modify some things for the kit to work.
Another question is what does the b18b redline at stock.
And my last question is what is an estimate of how much hp a turbo will give me with that engine push roughly 8-10psi.
Thanks to whoever can anwser these questions.
