Originally posted by 88bluehf@Dec 9 2004, 03:38 PM
get yourself a pr4 ecu obd0, get yourself an obd0 b18a1 dizzy, youll have to go get yourself some si front spindles b/c the hf's WILL NOT WORK. next you will need 90-93 teg axles and intermediate shaft.(must remove dust boot from inner spidle for this to work)be sure to run obd0 b18a1 injectors. you will have to move fan switch wiring from back of block to thermostat housing. possibly lengthen a few wires here and there. beat drivers side framerail in just below shock tower for alternator clearance. proper radiator hoses(think theyll be for 90-93 teg) possibly new throttle cable(hf might work) and maybe a few more misc. pm me if you need more info
[post=429572]Quoted post[/post]
Originally posted by 88bluehf@Dec 9 2004, 02:38 PM
next you will need 90-93 teg axles and intermediate shaft.(must remove dust boot from inner spidle for this to work)[post=429572]Quoted post[/post]
Originally posted by 1widecrx@Dec 9 2004, 03:05 AM
I have a b18b, cable trans,shift link, and mounts. what will i have to do to finish the swap
[post=429176]Quoted post[/post]
Originally posted by CRXSI91@Dec 9 2004, 06:55 AM
your gonna have to convert your car over to obd1 for starters.
[post=429232]Quoted post[/post]
