B18B1 is now running in EF/si...need help!
Discussion in 'HYBRID -> ED-EF / DA' started by Som1Dies2Nite, Jun 5, 2005.
  1. Som1Dies2Nite
    Som1Dies2Nite Member
    B18B1 idles hi so I connect the map sensor the B16A had on the firewall and now idles @ 1500rpms. What is the correct map sensor to use and any other sensors that need to be changed since the it was originally OBD-1 and now running OBD-0 with the correct ecu & dizzy? ANyone with vaccum diagrams would help..?
  2. B16CRX
    B16CRX Senior Member
    Greenville, SC
    the firewall map is fine. You say it is a OBD1 engine? You should either have a chipped P28 or the ECU that came with that LS (I dont know the code of the LS ECU). You will also need a Conversion harness for that ECU. I assume that since it runs you already have the distributor harness converted?
    Wait, I just re-read what you said....it doesnt make any sense. You have it running correctly with the OBD0 ecu and dizzy? or am I reading this wrong?
  3. B16CRX
    Greenville, SC
    Does this help you at all?
  4. Som1Dies2Nite
    Yes..Engine is off a 94 integra but decide to use the PR4 (OBD-0) ecu with the TD23U dizzy/B16A injectors and started on the first crank...It is (black) smoking but until I have all vacuums and sensors hooked..We'll see if it stops. By the way should I use the MAP sensor on the fire wall or use the the 1 on the TB?
  5. B16CRX
    Greenville, SC
    firewall. it is obd0 MAP.
  6. Som1Dies2Nite
    Thanks..
  7. clanny
    clanny Member
    Scotland
    It's perfectly fine to run an obd1 (or 2) engine with obd0. I have an obd2 b16b in mine running with obd0. Got 201 hp last rolling road at 8k. If you have the throttle from the b18 with the map sensor on it, I'd use that. The sensor will then be sensing the correct pressure whereas if you are using the firewall map sensor and plumbing it into the b18 intake manifold, it won't. It will be near enough but if you wanted to be pedantic....
    There is also supposedly a difference between the two map sensors. The obd 0 measures 1.7 bar and teh obd2 one measures 1.8 bar. I have also heard that the technical specs show this not to be the case but I haven't seen them so can't confirm.
