B18B1 motor mount and wiring harness?
viejo
I have 97 civic with a D16Y5 and i want to swap it with a B18B1, i need info on what type of motor mount i will need and which wiring harness. I have the ecu for the B18B1 and the engines wiring just need to find out which harness will fit between ecu and engines wiring.
well yes your gonna need to get a b18 tranny that's hydro and not cable and you need a mount kit from hasport or innovative for the ek b18 swap as for wiring the motor is obd1 and i believe your car is obd2 if that it the case then all you should need would be a obd2 to obd1 conversion for the ecu
