B18c Into Del Sol
twin t Vtec
98'Integra Type-R B18C into 95'Del Sol Vtecwhat mods need to be done(EXACTLY)
use your harness
swap injector plugs
swap distributor plugs
use the OBD-1 alternator or swap the plug
use your mounts and linkage
im pretty sure the 98 ITR ECU has an imobilizer in it .... so you might need to use your P30 ECU as well
