B18C Tranny help....
Discussion in 'General Tech and Maintenance' started by RFHOMI2U, Mar 18, 2004.
  1. RFHOMI2U
    RFHOMI2U Senior Member
    Ok, 93 Del Sol swapped with a B18C (hydro tranny)
    the other day it died, the clutch will not disengage. Tore the tranny out, found an "arm" that pushes the throw-out bearing when it is levered by the hydro fluid. Or something. It broke in half pretty much. Stage III clutch, so the dealership said it would not be a good idea probably to put a stock replacement in. Should we go with stock again? or should we get something stronger to hold up the clutch? Can't find anything stronger on the net. Thanks,
    - Ryan
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    the lever is called the shift fork. Really, I have never heard of "high performance" shift forks. How stiff is your pressure plate?
  3. B16
    B16 Super Moderator VIP
    yay area, CA
    ya, i cant' belive you broke it!! holy shit! lol... get another stock fork and shot peen it? lol
