B18C1 into EK
Discussion in 'HYBRID -> EG-EK / DC' started by SilverBulletEK, Oct 24, 2007.
  1. SilverBulletEK
    SilverBulletEK New Member
    Colorado
    I did a b18c1 into an ek hb and now i've got some issues i can't seem to solve.
    1. I'm boggin once it gets warm, but only in low rpm's
    2. Running lean code
    3. Hunting idle
    Anybody want to makes sense of this for me? Maybe throw out some ideas?
    Thanks.
  2. bompdrop
    bompdrop 12
    New Orleans
    bad 02 sensor?
  3. johnercivic
    johnercivic New Member
    What ECU are you running? May be the cause of it running lean.
    Hunting idle sounds like a bad IACV or a vacuum leak and maybe. This also could be in conjunction with the bogging problem.
    Hope this helps.
  4. SilverBulletEK
    Colorado
    thanks for the ideas, i think its an 02 problem and i'll check the iacv too, ecu is from a 99 gsr
