b18c1 motor into a 1994 del sol
teamsolo99
the del sol came with sohc vtec motor , then i did a motor swap to b16a jdm motor used the sohc vtec wiring harness added some wires , then i got a b18c1 98' gsr long block, i put obd1 injectors, obd1 gsr distributor, and plug it up , i drove my car at 6000rpms
the car hesitates until 7000 rpms it runs till red line, just wandering would it be in the wiring or the ecu , if any one could help thanks.........
