B18C1 Y80 Swap into 98 civic ex
Discussion in 'HYBRID -> EG-EK / DC' started by seattlenoob, Apr 30, 2015.
  1. seattlenoob
    seattlenoob New Member
    So, my stock motor blew up and what do you know, I have a friend with a B18C1 GSR mounted to a Y80 5 speed. And they are mine for free (great friend right?!). Here's the issue. I know what I need for the engine swap, but my ex came automatic transmission, and I have no clue what parts are needed to convert to a manual. Please help, lmao...
  2. whiterabbit06
    Crestview, Fl
    I'm feeling nice but you should really search there is plenty of reference material on this site. Engine mounts, axles, half shaft, shift linkage with tunnel mounting hardware, manual ECU, wiring harness, clutch pedal assembly and cut or replace brake pedal with a manual one to make space for the clutch pedal. Just to give you an idea of what you need. You can search to find what parts specifically you'll need.
