B18c4 into Sol touble?
Discussion in 'HYBRID -> EG-EK / DC' started by Paulo, Oct 9, 2002.
  1. Paulo
    Paulo Junior Member
    Hi guys, I'm new on here......don't have too much experience but here goes.....
    Thinking of swapping a B18c4 into my 93 DelSol, which already has d16z6 in it. I think the B18c4 isn't used in any USDM car, is this true?
    AFAIK, b18c4 is OBD2, is it recommended to swap for OBD1 (or go Hondata or similar)?
    Will I have any problems with driveshafts or ground clearances (already dropped 2")?
    I realise I will need different mounts, but any extra possible pitfalls, problems, tips or recommendations would be appreciated!
    The b18c4 seems like the favoured engine for the Japanese tuners!
    Apparently, Tatsuru Ichishima states that this is his favourite B series engine. And the B18C5 comes a reasonable second best. :)
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    just get the b18c1, alot easyier to find and will be cheaper. If you are going to upgrade the valve train there is not point. (the b18c4 is a Type R engine like the c5 right) Also to save you money, go with type R pistons, install them and you will have a type R engine for alittle less. Also to save you a big headache, go with obd 1.
  3. chet
    chet Senior Member
    st petersburg, florida
    i don't believe a b18c4 exists, in japan engines don't have numbers...its just b16a, b18c, b18b, etc.
    read this, i think the type r motor is certainly worth getting.
    i think spending 5000-5500 for a complete jdm type r motor is definitely worth it.
    here is what you get with the jdm type r
    type r throttle body
    type r intake manifold
    type r cams and valvetrain
    head is port and polished, has better flow
    type r pistons
    11lb flywheel (badass)
    type r 4-1 exhaust manifold (badass)
    type r transmission with lsd and 4.785 final drive (badass)
    8400redline, fuel cut at 8900rpm (badass)
    200hp, oem quality.
    basically, with the type r swap you get everything someone with a gsr swap wants. and, if you have the money, why not spend it on a motor/transmission, ecu that is already assembled by honda, which means oem quality.
    my opinion, if you can afford the jdm type r swap, buy it, and if you have to spend slightly more on a usdm swap, buy it.
  4. E_SolSi
    in Europe the Civic VTi from 97 on had the B18C4 in it
  5. chet
    chet Senior Member
    europeans got a civic type r, or the civic vti was basically a ctr?
  6. B16
    B16 Super Moderator VIP
    yay area, CA
    the B18C4 is a jdm motor, and yes, it is favored by the tuners. i think i read somewhere that mr. spoon himself (dont remember his real name) was saying the B18C4 is the best 4 cyl vtec motor, i think it was in honda tuner? or something like that. but yes, they do exisit, if you already have one, sweet, if not, good luck and happy hunting :)
  7. knowledge
    knowledge Senior Member
    Beale AFB, CA
    You are correct I remember reading that one! Not all JDM motors are just plain B18 or B16. They do have B18C1,s 2,s 3,s 4,s and 5,s!
  8. sisteve
    sisteve Guest
  9. Paulo
    Paulo Junior Member
    Well, the reason I'm thinking b18c4 is because I live in Scotland......it's easier to get a 4 here than a 1 as it's in the Civic Vti saloon (equivalent JDM SiR).
    Tatsuru Ichishima , the guy I mentioned in the first post, is the Spoon tech guy.
    I remember reading, I think in the FAQ section, that OBD2 to OBD1 is not always recommended
    So what I would be getting is a 170 hp euro-spec engine with OBD2.....NO CHANCE of getting a b16b over here unless you sell a couple of organs first!
    I was wondering if there are any problems in the swap which may crop up....hopefully if I go ahead with it, I would consider Type R pistons, cams and a few other bits n bobs.....but I'm unsure if the initial swap is worth the hassle......
  10. B16
    yay area, CA
    my car is OBD2, my motor is OBD2, but its running off an OBD1 computer, it can be done, and should not be that difficult. are there any smog laws pertaining to OBD versions in scotland? (ie: can you put an OBD2 motor in an OBD1 car, and run everything OBD1? here in California, all smog equipment must match the motor.) or is that not a concern?.... i wish i had a b16b :)
  11. wildbillhatchbac
    wildbillhatchbac the OG VIP
  12. Paulo
    Paulo Junior Member
    No laws about engine equipment in sunny Scotland, as far as I'm aware! ;)
    I can more or less do what I like as long as it's declared under my car insurance....and I need more power!
    So is this the way to go?
    There are no real problems apart from the mounts and the wiring harness to change?
    Should I get an OBD1 from an older car or just go for a Hondata or similar?
  13. paragus
    paragus Senior Member
    go with what you like, and what you want. it doesnt sound to shabby. And if the b18c4 is OBD2 you get a harness to make it go to OBD1 they sell them. And hondata only runs on OBD0 or OBD1 ecu's it doesnt sell applications for OBD2 ecu's.
    http://www.hondata.com/ecus.html
    "Should I get an OBD1 from an older car or just go for a Hondata or similar?" and i dont know what your trying to communicate here.
    If you plan on using Hondata then yes you are going to have to use a OBD1 ecu.
    side note: if im wrong on any of this... plz say so. :unsure:
  14. toyzbus
    toyzbus Member
    Western Nebraska
    I am using an OBDII b18c in my 94 ex. Since it was JDM and the harness was cut to crap, I ended up useing the d16 harness and modifying it. As long as you have an OBDI p72 ecu, you will be fine. For engine mounts you can use the ones from your d16, except the drivers, lower mount, which you will need to get from a Del Sol VTEC (there may be other cars in Europe that use the same bracket also, but I know that is what is needed in the US to keep A/C).
  15. Paulo
    Paulo Junior Member
  16. tb820
    tb820 Junior Member
    Hey Paulo... Does the block stamp actually say "B18C4"? Because from what I've read, seen, heard, and everything else in between is that the USDM Type R motor was labeled B18C5 and the JDM Type R was labeled B18C with no number at the end. I believe there is like a little serial number below the B18C that you would probably have to call Honda about to find out whether it is a B18C2,3,or 4. And b16, I've seen that interview with Mr. Spoon... Although I couldn't understand a word he was saying, the translation came afterwards saying that the C4 is the most balanced production VTEC motor there is....
    Paulo if you've got that B18C4, then roll with it..
  17. Paulo
    Paulo Junior Member
    Yeah, I'm sure it's a b18c4.....it's not a type-R engine(3 or 5, couldn't afford one of those!), not out an Integra, it's from the UK Civic Vti 4-door saloon 96-99.
    Is there a JDM equivalent of this? Not sure. The closest you'll get to a Vti is a JDM SiR.
    Looks like it should be quite a simple swap, and you don't get too many higher compliments than Spoon Sports talking it up! :)
  18. tb820
    tb820 Junior Member
    What you should do is write down that string of characters below the block stamp and call Honda or somebody who's got the resources and tell them the string of characters. They maybe able to tell you exactly what you've got. You could be sitting on a TypeR... :D
  19. Paulo
    Paulo Junior Member
    I wish!! Nope, the engine is coming out of a Civic Vti...But I can still dream!:)
    Hopefully I'll be able to push some extra power out of it to embarrass the Type-R boys! :p
  20. asmallsol
    how much power is that c4 pumping out? Is it the same as the gsr or more?
