B18c5 Eg Swap Problem. Need Help Please !!!
newEGtypeR
WASSUP EVERYONE !!!
I REALLY NEED SOME HELP HERE WITH MY SWAP. THIS IS MY FIRST.
I'M DOING A B18C5 SWAP INTO MY 94 CX HATCH. THE PROBLEM IS THAT I CAN'T GET THE SENSOR ON THE TRANNY ( which is on the firewall side ) TO PLUG INTO MY ENGINE WIRE HARNESS. THE TRANNY I'M USING IS A S80 LSD TRANNY. I'M ALSO REUSING MY STOCK CIVIC ENGINE HARNESS FOR THIS SWAP. DID I MAKE THE WRONG DECISION BY REUSING MY STOCK HARNESS ???
THANKS IN ADVANCE FOR ANY HELP !!! :) IT WILL BE GREATLY APPRECIATED !!!
I WILL POST SOME PIC'S OF BOTH OF MY HATCHES IN A FEW DAYS.
Do you have the plug from the type R harness or any other B series harness?
I've never heard of the VSS plug being different, but I've never heard of it being the same either.
Swap plugs with a B series if you have access.
I Don't Have A Type R Harness. When I Bought The Motor, It Was Just The Complete Bottom And Head. I Bought All The Other Parts Individually. Would Any B-series Wire Harness Be My Solution ??? Or Would Only The Type R Harness Work ??? My Main Concern Would Just Be Trying To Find A Type R Harness. Thank You For Your Input.
you will need a b series harness.. and take the plug off of that.. i got one if you need it..
