Originally posted by NotUrAverage_Si@Nov 27 2003, 09:53 PM
My brother has a b20z/VTEC set up in his Si. Completely stock internals. He takes it to almost 8000rpm's.
As for sleeving it, you could just buy another block for way less than the price it would cost to sleeve it. However, since b20's are like b18b blocks, they have no valve relief so yes it would be a good idea to upgrade your valve train, just incase. Webb makes very good and reliable valve springs and retainers.
It also wouldn't hurt to get a thicker head gasket to be safe. Don't get your head milled either.
So heres the low down: if you want your motor to last you a while or "forever" as you stated, then do only the necessary upgrades (valve train) or if you want you can go all out and get your block sleeved. DO NOT get on it constantly and maintain your car whenever possible.
The first thing I would do though is get a compression guage and check how much compression you're putting out per cylinder, I doubt it will be very high probably about 175-180 per cylinder depending if you have the b20b4 or b20z2 which has a higher compression ratio. If your compression is not too high than I just see sleeving your block as a waste, not to mention you'll be without your block for a while. So there you go, make sure your oil line isn't leaking and that all the fittings for the oil line in the back of the block are tight.
