b20 block vtec heads
Discussion in 'Engine Building' started by jdmcrx89, Jul 19, 2003.
  1. jdmcrx89
    jdmcrx89 Senior Member
    AL
    which vtec head is best for a b20 block? does it really matter? what all do i need to do to the head before i can stick it onto the b20z block?
  2. jdmcrx89
    AL
    anyone recommend any low budget cams for the head?
  3. word
    word Senior Member
    depends on your future plans, how much your budget is etc etc.
    all the b series vtec heads will work, read the LS/VTEC article in the reference faqs, b20 = bored b18b
    since you're gonna change the cams, i assume you'll get the valvetrain also. Just get a b16a head which should run you about 200-400 dollars for a bare head.
    low budget cams: b16b/b18cR (b16b's have longer duration), skunk2 stage 1's, etc etc.
  4. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    if your going to go with the R cams and you plan on taking the motor past 8200rpm's then you should upgrade to R valvesprings and retainers.
    Milan
