B20 help..
B20EFSi
gotta 89 si hatch with a B20b in it straight from tiger it ran fine for 2 days then it just died. the resistor box for the injectors came unplugged due to the clip being broke. then it ran good for another day then sittin at a light i just died. so i thought fuel pump so i replaced it with a stock pump plenty of fuel pressure good strong spark but will not start any idea's??? def need the help its my dd,
main fuel relay?
do you hear the relay click on for 2 seconds and then back off, when you turn the key to run. during this period of time you should also hear the fuel pump prime for 2 seconds.
if you still have the check engine light in the dash it should turn on then back off... if it doesnt id try another ecu
