B20 intake cam and valves
Discussion in 'Integra' started by Canyon, Aug 25, 2015.
  1. Canyon
    Canyon New Member
    I have a 1996 Integra. Blew out the b18b1.built a b20 motor. Have bc valves, springs, retainers etc. Stock cams. We put the motor together. No compression in any cylinder. Immediately went to look at the valve adjustment. The valves on the exhaust could be adjust accordingly. The valves on the intake side could not. The cams were never not having at least some degree of pressure on the rocker arms. What could cause this? Please help.
  2. Canyon
    Canyon New Member
    Also everything was built to specs using a Haynes manual. Everything was timed well. Checked timing over and over.
