B20 INTO MY 94 LS
PDOTJONES
I PLAN ON DROPPING A B20 INTO MY 94 LS IN A COUPLE OF WEEKS, AND EVENTUALLY GOING VTEC LATER. MY QUESTION IS FOR ANYONE THAT KNOWS ABOUT THIS SWAP OR THAT HAS DONE IT BEFORE. IS THERE ANY PARTS THAT I NEED OR IS IT A STRAIGHT DROP IN? MY OTHER QUSTION IS, WILL I NEED AN OBD CONVERTER, AND IF SO, WHICH ONE AND WHERE DO I GET IT???? THANKS FOR YOUR HELP..
Just swap the motor right in, they are interchangeable. Use your existing injectors and distributor and ecu, they'll work just fine. And drop the caps lock please.
