B20 problems my motor is spitting
Discussion in 'Civic and del Sol - EG and EK' started by B20 newguy, Oct 3, 2010.
  1. B20 newguy
    B20 newguy WTF
    MARYLAND FOO
    I have a 97 civic coupe with a b20 b16 cap which the vtec isn't workin rite and the mototr is spitting at times idk wat the problem could any tips or help would be greatly apreciated
  2. Pizzo
    Pizzo New Member
    Chicago
    To me with out hearing it, Sounds like you have a misfire. Is the check engine light on or blinking? Honda's, Toyota's are known for the distributor going bad. The gap between the pick up and shaft may have to much of a gap.. The gap between them is depending on year make and model.is normally 0.07 - 0.012..... If that is off it will cause a stall (misfire) or not even running conditions..
    Basically you will have to start checking everything Fuel pressure, timing, spark, coil.
    Make sure your wires are on correctly and routed the correct way I would check this first if the car was in front of me...
    The B16 cap that is installed Will that work on your engine correctly? IDK if that will or not??? Sorry IDK Why you would want a B16 cap on a k20 engine...
  3. PhyRe
    PhyRe Senior Member
    ct
