B20 question
Discussion in 'Engine Building' started by vietec, Oct 23, 2002.
  1. vietec
    vietec Member
    i am wanting to swap a B20 engine into my civic hatch, not B20 vtec yet but just the B20 alone for now, because i am on a tight budget. i was wondering whats the redline for the engine. plus do i need any mods b4 i swap the engine in such as mount kits, pistons cams, etc... does anybody know the quarter mile time for b20 engine in a hb?
  2. pissedoffsol
  3. phunky.buddha
    Dallas / Fort Worth, TX
    If you're on a budget, don't bother with pistons/cams etc... they cost a lot. All you really need is new mounts.
  4. [Jett]-CRX
    [Jett]-CRX Member
    Maumelle, AR
    :huh: am I the only one that doesn't see redline numbers in the reference section?
    Don't mind me... just being a smart @$$... :)
  5. vietec
    vietec Member
    i think i am getting the b20Z cuz it got more HP and Torque therefore faster, but there isnt really a difference when swapping b20b and b20z is there, they both 2.0 L ? oh and i am swapping it into a 92 CIVIC HB. is there a chance that the Mount kit will break cuz the b20z have a lot of torque for a light car. Plus is it safe to rev high. any answer would help thanks
  6. cxjon
    cxjon Senior Member
    man+k+toe
    if you go wit a b20b or z you have to get a obd 2 to 1 harness and there about 200-300 dollars... i think you need a ls intake manifold and a tranny for any b seires you want.
  7. pissedoffsol
    right- you need the ls intake mani on the b20b, but not with the b20z.
    and you need b-series tranny... the crv one is gay and has 4wd shit
  8. knowledge
    knowledge Senior Member
    Beale AFB, CA
    Convert your shit to AWD! Would be very expensive though.
  9. E_SolSi
    it would be easier to lower the shit out of a CRV and swap bodies with the civic
  10. knowledge
    Beale AFB, CA
  11. vietec
    vietec Member
    why does the b20z do not need the LS intake manifold? and the b20b does?
  12. phunky.buddha
    You should swap them both out. The B20Z has a shorter intake manifold than the B20B's "giraffe" setup (I think it's the shorter one, don't remember), and may fit under your hood. I'd still go with the LS intake manifold for both though.
