Am I missing anything?? Oil pump? Timing Belt? Nething necessary to run this setup.. I know that the cams, sleeves and traction bars arent necessary, those will be done later.. but I wanted to basically have a somewhat forged setup done and be able to run the setup with no problems.
B20 block
B18C5 head
18" -4AN steel braided hose
2 x -4AN fittings
1/8"NPT to 1/8" BSP Tee fitting
1/8"NPT to -4AN adapter fitting
-4AN to 3/8NPT fitting
1/8"NPT plug
JE Pistons 9:1
Eagle Rods & Arp Rod Bolts
Arp Head Bolts
RC Injectors 550 cc (peak and hold or saturated?)
Oil Catch Can
pcv mod for b20 block (this is a must)
Golden Eagle Godzilla Sleeves
Skunk2 Turbo Cams
Skunk2 Cam Gears
Machine Work on Head/Block
Hondata s200 w/ boost option
OBD I ECU (JDM ITR)
B18C5 Tranny w 4.7 Final Gear
VTEC Shift Linkage
AEM Fuel Rail
B Series Distributor
CM Stg 4 Clutch
Axles & Mount Brackets
ACT Street Lite 11.9lb flywheel
Traction Bars
B20 block
B18C5 head
2 x -4AN fittings
1/8"NPT plug
JE Pistons 9:1
Arp Head Bolts
Oil Catch Can
Skunk2 Turbo Cams
Skunk2 Cam Gears
OBD I ECU (JDM ITR)
VTEC Shift Linkage
AEM Fuel Rail
CM Stg 4 Clutch
Traction Bars
