B20b 6 Speed Tranny
Discussion in 'HYBRID -> EG-EK / DC' started by Acura_Racer1562, Apr 2, 2003.
  1. Acura_Racer1562
    Acura_Racer1562 Junior Member
    What Sites have 6 speed trannys that would go with my bf's B20B engine his car is an acura integra 92'
    ~This is his screename but I just wanted to know~ :rolleyes:
  2. brc80
    brc80 Senior Member
    Southern California
    Maybe im just in a bad mood today but can we ban this one please. :axe:
  3. omega11855
    omega11855 Senior Member
    Dude its cool to be in a bad mood but you could have just said that there arent any 6-speeds for his car actually there might be but the price of it would immediatly of-set its worth so the quick answer is no 6-speed
  4. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    The only way you could ever get a 6 speed in there is by buying a top end racing one which will cost you 5k minimum. Totally not worth it. If your/he is going NA, Integra Type R tranny, and if he is going Turbo ls or gsr tranny.
  5. E_SolSi
    wrong wrong wrong
    easy answer --- no there arent any 6 speed trannys available for D B or H series engines
    actual answer ---- no you can not have a high end company make one for you..... but...... it has been done.... you need to get a 6 speed tranny.... then get a custom bell housing made for it.... but uh-oh the engine spins in the opposite direction that every other engine on the planet does (so your gunna end up with 1 forward gear and 6 reverse gears) :bash: damn honda..... so you have to mount the engine in reverse in the bay (header near the firewall)
    apexi has this setup on their drag integra... they used an X-trac 6 speed tranny for it
    here is an article about it
    Apexi 6 speed H22A powered integra
    feel up to it???
    have the cash???
    have fun
  6. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    For some smartasses, you guys really don't do a whole lot of research.....
    It DOES exist. For 15+ THOUSAND dollars, Quaife will make their sequential 6 speed tranny work for your engine of choice.
    QUAIFE 32G 6-Speed Sequential FWD Gearbox:
    straight cut gears with open face dog engagement
    additional shaft support bearings for extra strength
    more compact design allows for easier installation
    differential accessed via separate cover for quick servicing
    QUAIFE ATB Differential
    compact drum type sequential design for faster gear shift
    range of detachable bellhousings from stock or custom made as required
    driveshafts made to suit your installation
    large choice of gear and final drive ratios
    gear ratios replaceable individually
    supplied with extension shaft for equal driveshaft lengths
    100mm or tripod output flanges
    digital gear position display available
    remote gear lever with optional length operating cables
    includes hydraulic clutch release bearing assembly
    oil capacity 2.0 liters
    32G BASE RATIOS
    2.615 1.937 1.611 1.350 1.160 1.044
    FINAL DRIVE RATIOS
    3.824 4.125 4.467 4.857 5.308
    gearchange rev drop @ 8000rpm shift
    1-2 2074
    2-3 1346
    3-4 1296
    4-5 1126
    5-6 800
    Mk2 6-Speed FWD, dog engagement sequential (32G) $15,795.00
    Mk2 6-Speed FWD, HELICAL dog engagement sequential (32G) $16,195.00
    Gearlever & cable, add: $2,150.00
    Digital display unit for sequential gearbox $750.00
    Driveshaft extension tube $795.00
  7. E_SolSi
    im pretty sure neither of those will work directly with a honda due to the reverse rotation of honda engines
    so you will still need to mount everything in reverse
