Just dont rev it like a B16, the the B20 wont hold together revving that high.
Define high rev please.
Mine tacks at 7200 but it never goes there unless i am at an autox event. Is that high on a fully built B20b with B16a head???
so you are telling me third gear might be a good idea
it could do a lot of good if u retune the power and torque curve..
If you "retune the power and torue curve" and knowingly put it out side the safe limitations of your engine your an idiot.
Also, why would even consider trying to move your powerband higher into the RPM range, when you can make the same power at lower engine speeds?
