OK....
What CR pistons will i need to go with in order to achieve
a static compression ratio of 10:1-10.5:1?
i have heard that the 9.5:1 pistons in the B20 are said to make for almost that ratio, when using a B16 head for the conversion
do you guys understand what i am asking?
i want to maintain a similar CR to that of my stock B16, so that if i want to add a SC, or low-boost turbo setup down the road, it will still be ok.
but, i also want the B20VTEC to make good power without the FI....
FYI: i will be running Golden Eagle sleeves, forged rods/pistons, etc...
and plan on a small nitrous setup for starters
