Ok so lets say i'm doing a crvtec outa my b16a2 (00 sir) and plan on doin some of it myself. (goldeneagle package) Would it make sense to use the b20z from the 99-00 usdms so that i don't have to waste money on getting the blocked tapped for a knock sensor?
i would say yes because you are going to need it and i wouldn't want to waste money on getting it tapped, unless you are planning on using an ecu that you will not need to use a knock sensor like a p28 but if you are going to leave your ecu as stock then yeah get the block with the knock sensor already on it
