Capt. Orygun
Win the Day
Alright, it's lower ball joint day on the S14.
pull the support arm (after using a 5lb sledge and a wrench to get the nut off the inboard mount bolts)
remove clip rings
use same 5lb sledge to remove ball joints from lower support arm
take a break (god that sucked)
put new ball joint in lower support arm, sandwhich between unreasonably large sockets and use 60,000lb shop press to install
BOOOOOOOOOOOOOOOOOOOOOOOOOOM!
It sounded like a gunshot. The short of it is that the socket on the lower side of the ball joint was on the sleeve where the joint bottoms out agianst the support arm, NOT on the ring which holds the joint together like it was supposed to be. Now that I think about it I should have taken a picture and posted it. It was fucking detroyed. The hex pattern of the socket depressed the sleeve until it plain ripped apart.... wow!
So I did the other side the right way and the new ball joint will be here in the morning....
remove clip rings
