Battery question please help
Discussion in 'General Tech and Maintenance' started by mozzandherb, Dec 16, 2006.
  1. mozzandherb
    mozzandherb Senior Member
    The negative battery terminal is loose. I realized this tonight after driving my car for a while I shut if off and then it didn't start. I looked and the cable was almost off the terminal completly. I was wondering if this could throw a CEL light and also my main question could a loose battery cable be a cause as to why my car has been bogging out a little bit? A couple of days ago my CEL light turned on and it was code 43 which is defective fuel system, so could a loose battery cable be related to that as well? Thanks guys [​IMG]
    __________________
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yes it will make your car bog
  3. mozzandherb
    Thank you thats what I wanted to hear
