Benefits of OBD1???
I currently run a b16 obd0. Is there any major benefits of swapping to obd1 on a basically stock motor?
you can turbo it just fine without going obd-1. since you don't have emissions, it would be a waste.
There is one major advantage that OBD1 has over OBD0 or OBD2. That is that all hondata ECU upgrades must be done to a OBD1 ECU and many other ECU upgrade companies only offer stuff for OBD1. This is probably not enough to make you want to change but its the main reason I went from OBD2 to OBD1.
just chip the pr3 and use BRE or turbo edit, both are great OBD0 tuning programs.
