best ecu for zc swap
Discussion in 'Civic and CRX - EF' started by goose2, Mar 22, 2008.
  1. goose2
    goose2 New Member
    what is the best ecu for a zc sohc swap in a crx?pr4,pm6,pm7?
  2. monotech909
    monotech909 Got V-tec?
    Inland Empire
    Pg7 or Pm7 ---> Pg7 rev limiter is set @ 7,500 Rpms stock I have a few available if needed
  3. goose2
    goose2 New Member
    so the PG7 : 86-89 Integra (86-87 vac advance, 88-89 electronic advance) will work in a 91?wouldn't the PR4 : 90-91 Integra LS/GS be just as good?
  4. BrutalB83
    Rochester Hills, MI
    Isn't the one that comes stock with the motor always the best choice? Why would you use a 90-91 Integra ECU? That's a completely different motor...
  5. goose2
    goose2 New Member
    more power.besides the pm6 and pm7 are impossible to find in automatic. i was told that the pr4 ecu would work for my application.was i told wrong?
  6. BrutalB83
    Rochester Hills, MI
    I understand you want more power, but just haphazardly sticking in a computer from a completely different engine isn't necessarily going to get you that power. A different ECU might raise the rev limiter or inject more fuel at certain points, but if the motor wasn't built to handle it, then what's the point? You'll just be fucking up your engine...kind of like installing one of those crappy E-Bay "performance" chips...
  7. efhondakid
    Akron-Canton, Ohio
    Why do people think a different ECU will make more power.
  8. BrutalB83
    Rochester Hills, MI
    Probably because they know someone or have heard of someone using a P28 or P72 or whatever for their built motor, and then assume that throwing a different ECU in there will automatically give you a power boost...
  9. monotech909
    Inland Empire
    Definately not true who ever said that must be a rookie.
    Pr4 will run rich it will work but will cause you to run richer not a good choice unless thats your only source.
    I would rather go with Pg7 or even a Pm6 but Pg7 for being stock is well worth it.
    If you get a Pm6 make sure its a 28 pin that way you can program it later if needed. Make it worth it if you happen to get a Pm6
  10. maykelcj
    maykelcj New Member
    hands down the best ECU I found for my ZC was a chiped pm6 with modified PM7 maps. I got it from a guy that chips them on theZCR.com. Don't get fooled the best ECU is the one made for your engine! I tied the PM8, PG7, and the PM7 maps make the car run like it suppose to run.
    you don't need higher rev limit on the ZC because ~6700 rmp it is done making power.
    here is a link to that guy. He is really nice and easy to deal with. www.thezcr.com - Auto Electronics
    if you decide to go for the PG7 I have an automatic one that I used for my ZC at first.
  11. monotech909
    Inland Empire
    Ericks racing can chip pm6 ecu and pr4 for your application.
    Hes done a few of my Pr4 ecus to work with my Ls/V-tec builds and does a hell of a job. Price is definately worth it. :thumbsup:
    ERE OBD 0 PRograms
