big oil leak need help
Discussion in 'General Tech and Maintenance' started by egb16, Jan 4, 2007.
  1. egb16
    egb16 New Member
    its a 92 civic with b16a2 oil is leaking big time from the back ofthe block of the block theres a hole that its leaking out of of some black box goes there connected to some tubes i found out. now does anybody know the name of that box thanks for the help
  2. fjac1207
    fjac1207 New Member
    Guatemala, Guatemala
    Oil Leak
    hey man I know You posted Id a long time ago but I have the same problem with mi Integra GSR is leaking when I park it, and the ondly place i can see the oil coming is from that black box I had de Factory manual and it's says that the box is an "Oil breather tank" I You repaired yours please make me know how, thanks!
  3. 99sidude
    Ohio
    The pcv valve goes into the top of the oil cooler (black box) on the back of the block. Make sure that the pcv valve is still there. If the pcv valve isn't there then that leaves a large hole for oil to escape.
  4. fjac1207
    fjac1207 New Member
    Oil Leak
    Thank's man I'm gonna chek it! I hope that's the problem because I don't want that be the head gasket it's to expensive to change!
