matts91hatchls
Member
ok guys ill give you the run down.....i was goin about 110mph last night, and shifted into 5th gear... as i do this the RPMS start to drop, the car stoped making power....... i got off the highway and the car shut off..... by the way it was bellowing out smoke from under the hood....
this morning i go out to check out the car... i found that the little black box that sits on the rears of the engine (closer to the passanger side)(between the starter and the oil filter)(covered in a squishy black cover) that was the cause of the smoke.... there is one 3 inch hose connected to it that goes to the back of the block.. and a hole that seems it should have a hose connenected to it, but i dont see any loose hoses that would connect it it....
This car is a 91 hatch... LS worked...
my questions are, do any of you guys have any pix of this, any experience with this thing, or know what is supose to connect to this
