Blackworks Racing Vtec Conversion Kit
Discussion in 'Accord' started by Honda419, Feb 17, 2011.
  1. Honda419
    Honda419 New Member
  2. Honda419
    Honda419 New Member
    nobody knows?
  3. eg6sir
    Holy crap... its in the link and u still spell it wrong...
  4. eg6sir
    No.. it will not make ur motor vtec... its for a b20 also
  5. BrutalB83
    Rochester Hills, MI
    :werd:
    I think that's a mistake on their website. That product shouldn't be listed under the Accord section. Read the description. That kit is for putting a VTEC head on to a non-VTEC B-series block...
  6. 95dc4iwantoboost
    95dc4iwantoboost Boost Envy
    Sacramento
    Get rid of the f22, and drop in any seris motor. b16, b18c. The kit is designed to add a b16, b18 head to a b18 or b20 block that has a head that doesnt have vtec. It it s speacial head gasket for the coolant and oil paths, as well as an oil filter adapter to add oil presure to your new vtec head. Including the tools to do the head work. You should read up on ls/vtec conversions to get a better understanding of the finer details of the swap.
    In your case, I would suggest dropping in a GSR motor. You can stay with a OBD1 motor because of the year of your car. That will get a ton of power for your application.
    GL.
  7. 95dc4iwantoboost
    Sacramento
    Sorry, meant to say any b series motor. I read right past it twice and didnt see it.
  8. eg6sir
    He has a 90 accord... don't u think a h22 swap would be more realistic
  9. 95dc4iwantoboost
    Sacramento
    If thats the case, might as well make it a K24. I was thinking more abundent engines, and cheapers parts. but yeah, you could also use an h22.
  10. BrutalB83
    Rochester Hills, MI
    Yeah, B-series doesn't really work in any of 90+ Accords. Not enough torque, plus the fact that you'd need custom mounts just makes it not worthwhile...
  11. 95dc4iwantoboost
    Sacramento
    Well, I gues you learn something everyday. today I learned no B-series in Accords. Drop in a h22, and call it done.
  12. BrutalB83
    Rochester Hills, MI
    Yeah, I mean I'm sure you could fab up some mounts and make it work, but I just don't see much point when even the best B-series engine has less torque then the stock F22 and you've got a 200 horse dual cam option in the H22 that's a direct bolt-in swap...
  13. calmfornow
    calmfornow System Failure Racing
    Zionsville, pa
    i cant argue with h22 swaps, like i say all the time, i did an h22 swap on my 91 accord and she runs fucking great, or the other option if your stock motor has low miles (which i doubt) and is in good condition is turbo the beotch, and no offense about me doubting about low miles, but what are the odds finding an accord with low miles any more hahaha
