acording to the Helms, Start at the Pasengerside Rear, Driver front, Driver rear, passenger front.
Put a peice of hose over the bleeder screw, the other end in a bottle (so that way you can see when it comes out clean) Have someone pump the brakes 3 times or so then hold the brake down, then you open up the bleeder screw quickly then close it (once the Stream stops). If your totally flushing the fluid, keep doing this until the fluid comes out clean. Make sure the resivoir never goes below the min line.
