Blower fan switch is stuck, brrrrr
Discussion in 'Body / Exterior / Interior / Cosmetics' started by boostpyro90, Jan 4, 2011.
  1. boostpyro90
    boostpyro90 New Member
    Hows this for a new epic DA integra problem?? On my way home from work I tried turning the heat on because its 23 degrees out and the fan switch will not spin, its stuck in the off position!! Has this happened to anyone? Any advice? I don't want to be cold!!
  2. hondafreak513
    hondafreak513 New Member
    O hi O
    pull the climate cluster out and check the switch it could of melted... then check the relay on the bottom of the fan motor it will have three 8mm bolts holding it in.. I had the same problem with my DA ...
