boost
Discussion in 'Forced Induction' started by aznhottiekj, Jul 1, 2003.
  1. aznhottiekj
    aznhottiekj Senior Member
    if i put nitrous into my 98ls will i need to reinforce anything, or upgrade anything, to keep it running safe??
  2. pissedoffsol
    fuel. depending on how big of a shot you go with.
  3. aznhottiekj
    fuel???
    you mean my fuel system or the fuel itself.............
  4. knowledge
    knowledge Senior Member
    Beale AFB, CA
    He means your fuel delivery system. You could run like a 40-50 shot safely with your stock delivery system. I would also recommend you use the highest octane fuel in your area also!
  5. calvin
    calvin Senior Member
    NETHERLANDS
    i think if u would go higher then 40-50 shot u will have to add a feul pump, maybe injectors.
    Calvin ;)
  6. SFPracing
    SFPracing Senior Member
    Miami, Florida
    YOu can run up to about a 65 shot wet with an upgraded fuel pump. Get an air fuel gauge and make sure it doesn't lean out, and don't miss to many shifts ;)
