Boosting an H22
1994accord
So i am thinking off dropping an H22 into my 94' Accord and boosting it as a project/learning experience and fun. I know there is a lot of work and $$$ involved. I want to be able to run 10 pounds DD very safely. Anyone kind enough to tell me all the things I will need to do? I know I need to bore and re- sleeve, lower compression pistons, bigger injectors, etc... I know i am missing a lot more.
Thank you:)
P.S. I wouldn't mind some opinions from people who have boosted H22's before;)
You forgot one thing; how much hp are you looking to achieve?
PSI should not be the number your looking at. Set a power goal, and then run the appropriate amount of boost. And PSI is relative to the size of the turbo. A large turbo flows many many more CFMs at a given PSI compared to that of a smaller turbo which would push lower CFMs.
also the cylinder walls are weak as hell.
He stated that he was going to get the block sleeved, so the FRM sleeves would no longer be an issue. Also, I'm not aware of any inherent weaknesses in the H22 transmissions. I think he would be fine with an upgraded clutch...
