Brake conversion done....or is it?
Discussion in 'HYBRID -> ED-EF / DA' started by drpenguin, Sep 1, 2005.
  1. drpenguin
    drpenguin Senior Member
    Salem, Or
    Well to get the B16 into the rex I had to put on new hubs. The back drums wernt cutting it so I switched to 93 rear disc. My brakes work great but i have to push my pedal way down. Someone told me that since my trim is HF the master cylender (?spelling) is to small. Anyone know about this?
  2. Speedracer228
    Speedracer228 ......
    i just did this swap as well, there are pics and hwat not in the link in my sig
    I switched to a 91 ex 15/16 mc and it made a huge difference. Also id upgrade to the 4040 proportioning valve from an integra as well to get the full potential of your rear disks. Otherwise they arent getting any more pressure than ur stock rear drums.
    My brake pedal is now wonderful and it brakes awesome
  3. GSRCRXsi
    MD
    ive always wondered about this statement, since a stock 90-91 crx si (which has rear discs stock) has a 4020 prop valve.
  4. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    smaller rear discs maybe, need less pressure?
  5. GSRCRXsi
    MD
    all civic/integra rear discs are the same size (9.5") with the exception of ITR.
  6. drpenguin
    Salem, Or
    okay so say im at the junk yard. What car would be the best to rob the master off of? I was thinking of going back to the teg that i got my front hubs from and take that one. The pedal is fine and stops great it just goes down farther then i would like
  7. brian11to1
    brian11to1 Senior Member
    master cylinder and booster from 94+ gsr or 98+ itr. full 1". or atleast the prop valve and master cyl. from 90-93 integra.
  8. vtecsir1
    Orlando, FL
    you can get the prop vavle from a 94-95 rs like i have
  9. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    the prop valve from a 90-93 teg yes, the master cylinder, NO!! Unless you plan on swapping to the integra brake booster also, the integra master will not work. it does not bolt to the CRX booster. you need the master from a 91 civic EX.
