brake drums
Discussion in 'Wheels / Suspension / Tires / Brakes' started by cxjon, Oct 3, 2002.
  1. cxjon
    cxjon Senior Member
    man+k+toe
    if i want to get new drums what is better OEM or brembo
  2. cxjon
    cxjon Senior Member
    man+k+toe
    my drums are rusty as hell and i was thinking of getting new ones
  3. B16
    B16 Super Moderator VIP
    yay area, CA
    i say convert to disc, got my whole rear disc conversion for $170 which included oem calipers, rotors, pads, rear trailing arms, and ebrake cables
  4. knowledge
    knowledge Senior Member
    Beale AFB, CA
    Its just the outside that is rusty huh? I cleaned mine up with a wire brush and some sand paper! Try that for now.
  5. cxjon
    cxjon Senior Member
    man+k+toe
    the bembro are abot 22 dollars each i was wondering if i should stick oem on buy tho's.... when i put my rims on i had to kick off my old rims cuz there so rusty on the drum
  6. cxjon
    cxjon Senior Member
    man+k+toe
    i dont need disk brakes in the back that is why i m asking if anyone know it the brembo's are good or not ... or should i stick with oem drums
  7. iVtec
    iVtec Member
    drums are not cool...if your goin to spend money get rotors....
  8. pissedoffsol
    i think you'd be better off, both money and brake power wise, to do an oem rear disc swap.
    i bet its cheaper than buying those aftermarket drums
  9. cxjon
    cxjon Senior Member
    man+k+toe
    there only 22 dollars a drum
  10. paragus
    paragus Senior Member
    in that case the drums are cheaper. ALOT cheaper.. if your worried about the looks. cuz its rusty. And you dont need new drum brakes. Just sand it down and paint that shit black. And save for a disk swap :p
