Well this morning drivin to work like any other day. well I get off the highway
start to slow down no problem, then coast a little as it's a long exit ramp uphill, hit the brakes gain except this time the peddle almost goes to the floor still stopping me but scarey. continue on my normal route keeping at a much slower speed than usual, put the brakes on and the peddle goes much closer to the floor than normal and doesn't feel like it has as much force (the pressure you feel as you apply the brakes).
I took a peek under the hook looked at the resivoir and it's not at the MAX line but just under so I doubt that the problem has to do with low brake fluid.
only things crossing my mind, rear drum brakes (that little thing that actuates the brake is shot and pissing fluid in the drum) , a brake line broke, or the master cylinder is shot, front caliper is fucked up , I guess hell it could be anything.
Anyone have any ideas what might be wrong ???
