calmfornow
System Failure Racing
shyo peoples.....so to start with the car, it is a 91 honda accord LX 4dr. my brake pedal goes to the floor, and i have to pump the brakes to get pressure, if i pump the brakes the pedal goes up, i get pressure, and she stops. i first replaced the master cylinder, didnt fix it at all, so i put another new one in, and still no work. i bench bled both cylinders also. i replaced one caliper, and the slides are greased nice. i also bled the system like five times, but i bled them from "driver rear, passanger rear, passanger front, driver front". i was told with hondas you have to bleed criss cross, i didnt know if this would fix the problem.
new master cylinder, tested and good brake booster, no leaks, new D side caliper with both sides greased, and pedal still goes right to the floor.
please help on insight/input
thanks
thanks
