Andrew
Active Member
I have a 1991 Crx si, so it has 4-wheel disc brakes. Here are my questions
1. I was wondering if I could install front calipers on the rear?
I'd obviously need to put front-size rotors on there, but was just wondering if the calipers would mount right in, with no fabrication, or are the brake lines different sizes(planning on getting braided lines to install too)
2. What are some good aftermarket Rotors and calipers to use?
I know there are those slotted and cross-drilled rotors, but I've read that they arent as effective as regular ones. Is this true, or are they a wise investment?
Will my stock calipers work for daily driving(duh) and some agressive driving/autocross, or should I go ahead and invest in some new ones?
Thanks
-Andrew
Thanks
-Andrew
