you would need brake lines. are you replacing the ones off the 5lug swap or upgrading to stainless. if you upgrade you will need the lines meant for the brakes like this :: 4/disc ABS/non-ABS. You will want to invest in an integra master cylinder and booster (94-01). and a prop valve from an integra or civic Si (99-00). it mainly depends on if you have ABS or not.
All that stuff will be nice, this is a CTR 5 lug, not an ITR 5 lug. So can I atleast get the CTR 5 lug on w/ out upgrading or replacing the lines for now?
