brakes????
roman_pushkin
have a 90 accord ex with drums brakes in the back and found a nice deal on some disk brakes for the rear like $50 for both sides with the whole complete set up and was wondering is it worth changing and will it be hard thing to do?
I thought all EX Accords had 4 wheel discs from the factory? I know my 94 EX did...
some do some don't cause my accord is a japan made and my friends is a usa made and he has disk brakes in the back and i have drumbs in the back
Is it a rear disc setup from the same chassis Accord? If so it's basically a direct bolt on process and should improve your braking power at least to some degree. If nothing else it should give you a firmer brake pedal.
