break - in procedure
Discussion in 'General Tech and Maintenance' started by PLA5151, Jun 7, 2005.
  1. PLA5151
    PLA5151 New Member
    Puget Sound area
    how do you actually break-in a clutch? rpm limit? is cruising on freeway at 3500 ok? can you give your car some gas thru the gears even though you are not high-revving?
  2. pissedoffsol
    variation is key. DONT stay at any one rpm. bring it up and down . if you're on the highway a lot, cruise between 55 and 75 back and forth, and hit 4th from time to time.
    DON'T launch on it hard or try to power shift. usually 200 miles is good enough
  3. vtecjdm
    vtecjdm Senior Member
    Interesting question ... i`d like to hear more comments about it
  4. PLA5151
    PLA5151 New Member
    Puget Sound area
    so you can pull ALL the way thru gears....just don't shift??
  5. jdm2gen03
    jdm2gen03 Senior Member
    yes that is alrite but dnt go doin that all the time in the break in process, jus acouple times is all u need.
  6. B16CRX
    B16CRX Senior Member
    Greenville, SC
    I drove easy on mine and would do a few pulls on mine when I got it, and now it grabs and makes the car jerk under normal driving. Did I do somethign wrong? This is ProClutch 2200PP an organic disc.... <_<
    EDIT: If I try to, I can make it not jerk, but I have to make a conscious effort to do so. and it doesnt seem to be jerky like that if I take the rpms to, say 4.5K and shift. only on low rpm shifts.
