broken cam cap studs?
Discussion in 'Engine Building' started by 8secHonda, Apr 11, 2010.
  1. 8secHonda
    8secHonda New Member
    i just reciever my b18b1 head this week and while attempting to take the cam caps off the bolts were ungodly tight.. well a few of the bolts broke off in the head i was using a 1/4 inch drive rachet..
    can a machine shop drill and tap these holes or is this a total loss?
    thanks for input guys....
  2. Magana559
    Magana559 The Warden
    fresno Ca
    You can Drill them with a smaller diameter drill bit and use a Easy out to get em.
    If your going to re use the bolts Torque them down a lil lighter lilke 4ftlbs less.
  3. 78civic
    78civic Junior Member
    NW MS, Y'all
    I'd just see if you could:
    1- get a center punch in the center of the bolt that broke.
    2-drill down the remaining length (compared to another non-broke one) stepping the sizes larger until you can get close to the 6mm stem size.
    3-tap it out to clean the threads up.
    Now your done and doin the happy dance..
    Not really.. I've NEVER got one to drill centered and always take out some threads. Hoping that the repaired hole won't EVER let loose because you tore up the seating surface of the threads..
    Take your time, use some lube (NEVER DRILL ANYTHING WITHOUT LUBE) because if you break a drill or worse, and easy-out in there you're screwed. They're harder than the tools to get the first mess-up out.
    E
  4. 8secHonda
    lol aight yeah dont wanna break those in there i thought about drilling it any installing a helicoil in it but not sure they make one that small lol... gonna get up w the local machine shop today n see how the charges loook.... thks 4 replys
  5. b18b1integra
    b18b1integra New Member
    Where by chance can i get cam cap bolts i snapped 4 replaced the head now im short 4
  6. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    ebay or junkyard
