broken temp guage?
Discussion in 'Civic and CRX - EF' started by blasterman87, Jul 30, 2009.
  1. blasterman87
    blasterman87 New Member
    my temp guage wasnt working, so i grounded it while the key was on, and it shot to "hot" so that told me it is working right.. but now its stuck at "hot" wont move either way.. did i break it or what?
  2. DBCustoms
    DBCustoms New Member
    not necessarily......
  3. blasterman87
    well what can i do to make it go off "hot"? and work
  4. gatto-is-alive
    gatto-is-alive New Member
    EARTH
    probably the pointer is stucked due to the to the ubnormal movement
    try to tace the cluster sheild off and put it down slowly with your finger thts i all i can say
  5. D16SiHatch
    D16SiHatch New Member
    i believe i read somewhere that if you short out the temp gauge and peg it at hot you will damage it irreparably. you could try pulling it back to where its supposed to be, but i'm going to take a wild guess that its beyond fixing at this point.
  6. 78civic
    78civic Junior Member
    NW MS, Y'all
    You grounded what where?? Sending unit or gauge itself??
    E
  7. blasterman87
    the guage wire that connects to the sending unit, i was told thats how to test the guage, it went to "hot" and is stuck there..lol i have a diffrent cluster i can try so we will see
  8. jlicrx
    jlicrx Senior Member
    Colorado Springs
  9. blasterman87
    i checked the guage, its 1 single wire.. and in my helmes manual it said to ground the wire, and if it reads "hot" then its in working order..but now its still"hot" lol
